jims87flh
Banned
The only way to clean it up if it has clear coat on is remove the cover use a paint stripper to remove the clear coat then polish the alloy and re apply clear coat
you'll need a heat resistant clear coat suitable for bare metal
did all the covers on the Sportster this way
or strip off the clear coat and polish the alloy every couple of weeks
actually, some fine scotch brite, followed by a bit of super fine wet sanding with take off the clear coat, and polish the area with a good all metal polish, like lucas. Then if you are careful, using some painters tape, news paper, and tin foil, mask off everything around it, and spray on new clear coat
