Also, while you're inside the fairing, might want to go with the hidden antenna so you can get rid of the rear whip...just a thought.
My plan is to put the bike on the lift and tear apart the fairing...I want to put in the Hog tunes and the hidden antenna..I would like to clean up the rear end also..This dynazorb is $50 for two 6x6 squares...anyone find it a great improvement? How do to glue it in ? I also want to put in a weather proof 12v hole to replace the stock one that I have lost the lighter part and I want to be able to plug stuff into it..Any other in the fairng improvements while I'm in there?
Thanks
Hap
I don't know if I'd call it a "great" improvement but the dynaxorb does help improve the sound quality of any speakers you have in there, even stock. I believe it came with a tube of glue.
Other in fairing improvements? May want to consider these:
1. Osram headlight bulb - Brighter Headlights - Harley Davidson Community
2. Replace air temp gauge with oil temp gauge - Oil Temp Gauge Installation - Harley Davidson Community
3. Replace or strengthen the fairing braces - many have had problems with them failing.
Doc,you found the self help section of the forum!!:lolrolling
