If that noise is from the primary side, it could be the race for the inner primary bearing behind the clutch. I have had had to replace mine twice so far. It is most noticable at idle and goes away if you pull the clutch in. You can put a lot of miles on before it fails. A friend of mine rode thousands of miles to get home before fixing his. This was a common problem on the 2009 models.
