So which model did you buy? I don't see any for $300.
I don't even SEE the pics of the one he bought !!!!!!??????!?!?!?!?!?
OR THIS ONE??Could it be this motorcycle lift? Seems mighty fine to me and the price of admission is decent...
- Harbor Freight Tools - Quality Tools at the Lowest Prices
[FONT=arial, sans-serif][/FONT]![]()
[FONT=arial, sans-serif]Foot-activated pump leaves both hands free for positioning and stabilizing your ATV or motorcycle. [/FONT]
[/FONT][FONT=arial, sans-serif]Capacity: 1500 lbs. max.; Lift range: 4-1/2" to 16"; Overall dimensions: 4-1/2" H (collapsed) x 15" W x 32" L; Pad dimensions: 2-3/4" W x 13-1/4" L x 1/4" thick; Ram travel: 5-1/4" L; Casters: 1-1/4" W x 2-1/2" diameter[/FONT]
- Collapses to just 4-1/2" high for easy storage
- Wide, low profile base with rear-mounted ball bearing swivel wheels
- Rubber grip pads on lift saddle protects motorcycle frame
- Four lockable work heights from 4-1/2" to 16"
- Rubber grip foot paddle prevents sliding
- Two-hand wheel brake prevents lift movement
- Return spring for automatic release
- Professional quality power unit and rust inhibit coating on ram and pump piston for long life
- Extra long handle for easy lifting
[FONT=arial, sans-serif]Shipping weight: 75 lbs.[/FONT]
[FONT=arial, sans-serif]ITEM 2792-0VGA[/FONT]
[FONT=arial, sans-serif]$89.99[/FONT]
Having a bit of trouble with this picture thing...I will try one more time.
