Here is my 09 SG with lepera Villain. Very easy on the rear end for long hauls and over the stock seat very good for the passenger as well. One thing to be very careful of is that the seat does NOT touch the ECM main plug, if it does you must cut the seat to clear it or replace it take your pick. As the stock plug cannot take any pressure at all!!!! HD has a issue with the plug as it is, applying pressure will induce failure and the most common issue is FBW problems
I did not have fender on it at that time.
