On my last tube tonight, and the 6mm hex bolt stripped. Any ideas on how to get this out would be appreciated! Thanks.
Thanks Jack and Petie. Haven't used a spline drive before. Is this something I can get at Home Depot and do you have a link to what I might be looking for? The bolt didn't crack, so its still pretty tight in there.
If you have a Northern Tool Supply close by here is a link for one offering from them. While not as good quality as the Snap On tools they are usually better than the Harbor Freight offerings IMO.
Irwin Multi Spline Screw Extractors Pc. Set | Screw Extractors | Northern Tool + Equipment
REX104A, Extractor, Multi-Spline, 1/8" Here is what I use @ work, You may find these @ Lowes, Harbor Freight or Napa The Snap On ones I have have the size drill to use stamped on them pretty fool proof
Jack your post are spot on and give all the info anyone could need. Reminds me of a certain HD guru we all know.:bigsmiley28:
