jaxdwg
You used the words "at least 250#" when speaking of the weight difference between the two bikes. I was hoping when you said 250# it was really more like 175#. Now using the word "at least",, this is worse than I thought. If that is a true fact and not just an wild estimate, your going to need more than a little extra fuel to offset that much weight with horsepower. Your talking about 25% of the total weight. I think your going to need a bunch of HP to offset that and I just can't see you extracting that much muscle by just adding more fuel.
How does your bike inject spark advance. Would you know what the curve is. Is it triggered from a crank sensor or is it a self contained module with window trigger/reluctance etc.?
He has the ultra with everything he can get on/in it, stereo gps, backrest, a full dressed out bagger. I have the 02 wideglide with just bags and a windshield, he weighs 190 , i weigh 220. He is the one that is about 250 heavier than me. I have done nothing to the ignition system of my 02 wideglide, the crank sensor does it's thing as it has since new. I was referring to what people use as a basic setup when doing engine upgrades, you know, these piston and these cams and this jetting , for a basic setup and break-in then go get it dynoed to get it right on. If I build a 350 chevy and put in a 275 horse cam and such, I know I can take a 600cfm holley and drop it on there and get decent performance with the stock jetting that comes in the carb. I was wondering if the 195 with what i've described above is a decent ballpark figure to work with?
