I'm running a complete HD stock ignition and coil set up with stock ignition factory curve.
Petcock doesn't have a leak, I pulled the vacuum line and there is no gas in the line. Crank sensor has been changed, coil has been changed. The bike doesn't have VOES it has ECM and it was changed also. I live in South Florida, no icing on the carb - even though we've had some exceptionally cooler weather, it is now back up to high 70's and it's still doing the same thing. Air filter has been cleaned, then changed for a new one. Runs on both cylinders.
