J
Jack Klarich
Guest
You can safely use propane from your small torch to check for intake leaks:s
I would not recommend using "starting fluid" for this check. WD40 or carb cleaner is less volatle. Has this always been a problem with this bike? Or did it start after a maintenance action happened?
I had cleaned the carb and went through it thoroughly yet still have problem. Prehaps I'll get the wd or starting fluid out and check manifold gaskets.
Do you have a 46 pilot? I would try it. At 3-1/3 turns you are at risk of loosing the adjustment screw. Have you done a compression test?
