R_W_B
Senior Member
..... . . . .Regarding this shifting matter:
Anybody had to replace the bushing for the shift shaft (from the toe shifter to the linkage to tranny)? .. . . . . . .. For any and all who page through the manual, I thank you!
Does this help Mike ? (attached parts exploded view at bottom) You can further view and purchase these at,
Ronnie's Harley-Davidson's 2008 Harley-Davidson® Motorcycle FLSTF FAT BOY® (BX)
1 SCREW 1
2 SCREW 2
4 WASHER, NYLON 1
5 WASHER 1
6 WASHER 1
8 ACORN NUT 1
9 RETAINING RING 1
10 O-RING 2
11 RING, SHIFT CAM RETAINING 1
12 RING, SHIFT CAM RETAINING 1
13 SPRING, DETENT 1
14 DETENT ARM ASSEMBLY, W/ REF # 13 1
15 CAM, SHIFT 1
16 SHIFT LEVER (CHROME) 1
17 BEARING SLEEVE 2
18 SHIFTER ROD 1
19 LEVER, SHIFTER ROD 1
20 SHIFT LEVER KIT, W/ REF # 2 & SHIFTER LEVER 2
21 SPRING, SHIFT LEVER CENTERING 1
23 PEG, SHIFT LEVER 2
24 SPRING, RATCHET LEVER 1
25 SHIFT MECHANISM, W/ REF # 21, 24 1
26 CENTERING SCREW, SHIFT LEVER 1
27 SLEEVE 1
28 FORK, SHIFT 1ST -2ND 1
29 FORK, SHIFT 3RD -4TH 1
30 FORK, SHIFT 5TH -6TH 1
31 SHAFT, 5 -6 SHIFT FORK 1
32 SHAFT, 1 -2 & 3 - 4 SHIFT FORK 1
33 SLEEVE 1
34 SCREW, DETENT 1
35 LOCK PLATE, SHIFT CAM 1
36 SCREW, SHIFT DRUM SUPPORT 2
37 OIL SEAL 1
