BUBBIE
Well-Known Member
Just turned 20005 miles on my 2007. Changed all 3 holes this week. I have run Syn3 in all three holes since new. However I'm thinking about changing to Mobile 1 20/50 next change. My vehicles are all with Mobile 1. Check your owners manual as some older bikes take a different grade in the primary or transmission.
HOPE YOUR TERM Mobile 1 is not PUT in all three holes.... it's a good synthetic oil but ENGINE OIL
suggested for engine okay BUT for the other holes
chain/clutch use a (made for) primary lube oil
tranny use a GEAR OIL>>>>>>>>>>>>>>spectro or redline shockproof hvg...It will shift better/quiet running/LAST LONGER
YOU"LL BE THANK NOW n LATER
READ in oil section
syn 3 is a SIN..
people who have used it in all three holes have had premature WEAR.....
In primary, CLUTCH HANG-UP DRAG ,plates disc not disengaging..
JUST NOT A GOOD LUBE.... at all
THIS TYPE OF POST WOULD BE SIGNED BY MANY(most if not ALL) ON THIS SITE.
ALL INFORMATION ON OIL IS HERE IF YOU READ ...
LOTS OF KNOWLEDGE IN THE DIFFERENT POST FROM THE MEMBERS and MODS. HERE..
read and learn from the BEST
