BUBBIE
Well-Known Member
Theres a guy on here that just turned 100k on his ultra using h/d syn oil in all three holes, all original motor and trans. I think that says more then enough about the quality of the oil. Some oils [may] be better then others, its just a personal choice for you to make. Truth of the matter is, as long as you change the oil regularly, it really doesn't make too much of a difference which oil you are using.
The thing I have seen is the Tyranny shift forks getting HOT from the heat by using a Light Weight oil (syn3) instead of a Gear oil.
And NOISE
Another problem was noted on HDT member, Their clutch hanging up when using syn3 instead or Formal+ or a good Primary Wet clutch oil..
No debate Just MY Preference .....
