gator508
Experienced Member
I solved half the problem!!! Thanks to all of you! :small3d028: Turns out the rear brake switch, which I recently replaced, twisted loose. My bad for not tightening it sufficiently. I still need to replace the front brake switch.
I'm a little confused after reading the manual. :newsmile108: Do I have to disengage the throttle cables from the twist grip to access the front brake switch?
If the rear brake light switch was loose you may have gotten air into the brake system, I would bleed the brakes before taking it out for a ride.
