Stonecoldcrb; Did you get the issue with your brake light worked out? I'm having the same issue. I changed the bulb first to no avail, then the fuses, and still nothing. I hear a click when both brake levers are activated but not sure if it is the relay or not. If you found the issue was it in the wiring near the rear fender like fin 676 advised? I Need help!
