Thanks all for the replies! I swapped out the intermediatte jet to a .032 since I had one on hand to see what it would do. Well getting much closer after that, I ran the last bit of gas out and filled up on a fresh tank. I'm getting it to idle a bit better and lower now. It is still running good with the throttle twisted and rolling above 50 mph. It's struggling at low speeds while just idiling along anywhere between 15 - 40 MPH. It's not so much a pop or back fire but it's like the engine is running like bom bom bom boooom bom bom, until you pour the gas to it and it comes alive. Sorry for the sad imitation!! HA
Not to much to report, I have been tweaking it back and forth and I have it running pretty darn good. I spoke with my engine guy in the states that slipped the crank in and he said the stroker motor is going to be night and day different than what I was running. With that it makes me feel like it is about as good as it is going to get. The main reason is it runs awesome with the throttle open and I don't have anything like a spark plug knock going on. So I found a dyno here in the UK and plan to give it a run to check it over and see if it's doing about the best I can. Hoping to top my 115 hp run after my 95 upgrade. Will post all dyno charts after complete.
Well, all looks good now! Thanks for all the inputs gentelmen! I put that last jet in and tweaked it to a fine line. Rode it for some time and all seems to be great. I think I will bump the jet up one more time since my window of adjustment is so tight. The cool guys at Ekquire motorcycles ran the dyno for me and suggested that might also fix the low idle tweak I need. The bike fires right up and runs pretty darn good, it just likes a bit of attention while idling. I have attached my dyno sheets to share as well, not to darn bad, right about where I was hoping. The lower one is when I was at a 95" and the upper is the latest upgrades.
