jaceddie
Junior Member
I found the stator burnt as expected. I have another regulator off an 03 ultra that was changed out for chrome when new. I'm retired, so money is an issue. I hooked up a 12VDC power supply to it so I could check it against the old one. It tested the very same! With 12VDC across the leads that go to the battery and ground, it still shows 12VDC on the pins. I know you can't trust a new part to be good, but I know this one worked when it was taken off. So.... I'm wondering if I'm doing something wrong when testing it this way, and is there a chance of burning the new stator if I use the 03 unit? I know it's hard trying to figure out a problem without laying your hands on it, but your thoughts would be appreciated.
