When the oil in the primary is cold it will be a wee bit thicker than when hot the oil is part of the grip on the clutch by creating an air tight seal between the friction pads and the smooth plates in the same way that some water will assist a rubber sucker to stick to glass
To assist with a smoother shift into 1st when the bike is cold holding in the clutch leaver for up to 30 sec will allow the spinning clutch to throw the oil clear of the plates
I have in the past had bikes where the friction material on the clutch plates was cork and the bond between the friction plate and smooth plate was created by the oil sealing the space at the edge of the cork pads
