J
Jack Klarich
Guest
Checking ad tightening heat shields at oil change intervals, I hate when they squeak
Let me start by giving this advice.
Don't make the mistake of jumping to the conclusion that something horrible is wrong with your bike if you start hearing a new noise. Consider all these easy, possible solutions first:
1. Did you recently switch helmets, jackets, glasses, or anything else that could cause an unfamiliar noise?
2. Did you pick up a piece of paper or stick or anything that could be stuck out of sight but moves around when the bike is in motion?
3. Carefully check the contents of all saddlebags, tour packs, windshield pouches, etc.
I kept hearing a soft "click, rattle" noise. I knew it was coming from the front end. It was the "Heritage Softail" script on the front fender. Pushnuts were loose. Got new pushnuts and problem was solved.
