Finally got out to do some testing today. I must be getting more heavy on the rear brake than I realized or should be doing for that fact, but when I go heavy on the rear brake to simulate a panic or quick stop maneuver, I get this "click " that I can feel being transmitted through the rear brake lever and onto my foot as its on the brake pedal. I also "feel" that slight change of momentum I commented on on my initial post, which is like that slight surge you feel when you shift a gear accidentally without using the clutch. I must have mistakenly thought that clicking that I was feeling thru the brake lever, was something going on with the transmission. Not sure how I put those two together, but doing some testing when I was paying attention, this is what I'm getting.
Now I've never had a bike with ABS, can I assume this clicking that I can definitely hear and feel, is normal behaviour on an ABS system?
I must be stabbing at the rear brake pedal when I have to get on the brakes quickly, and I know the rear is not where you get maximum braking power and that this is not proper braking technique. Definitely need to work on that.
