dolt
Well-Known Member
The 21 cams have the same base circle as stock, not that it makes any difference since the OP is using adjustable pushrods.
Just make sure that the lifters are on the base circle when finding 0 lash. Several ways to do that to be sure; pick yours and re-adjust. IIRC, the SE pushrods PN 18404-08) are 24TPI and setting preload at about .130"-.140" should quiet things down. That would be 18-20 flats, or 3 to 3.5 turns. If that doesn't help, time to look at the lifters, althoug, as Bubbie points out, the OEM "B" lifter is the best of the OEM lifter. Having said that doesn't mean one can't go south.
