Jeff might your cables be nylon coated instead of Teflon????
No, as dolt said most come that way now.
He was one of the greatest!!!!!!!!!!i think that is how evil kinivel got his start
Read your post here and it is dead on. Thanks, saved me money and head ache.Wanted to wait until verification of TBW and that the twist grip is moving freely but there is at least ONE more thing to try. The throttle twist grip will move "forward" (opposite direction from opening the throttle) a small amount. That is an option to disengage cruise and starting in 08, I believe to turn EITMS on and off. That is why I asked about holding the front brake at shutdown. If the twist grip is rolled forward when the engine is turned off, that position is remembered by the ECM as the desired idle value. When the twist grip springs back to its normal position the ECM sees that as a throttle increase thus commanding the throttle to open a bit and causes high idle at the next start, even after warm up.
To reschedule the ECM back to the normal twist grip position being proper idle do the following. Have the RUN/STOP switch (on the switch box by the throttle twist grip) in RUN. Do NOT touch the twist grip. Turn the master switch (on the tank) on and off 4 times, leaving it in each position for about 3 seconds each. Don't start the engine during this process. PROVIDING that the accidentally rescheduled idle setting in the ECM is your problem, the engine will now idle normally. Avoid accidentally putting any forward pressure on the twist grip at shutdown and you should never have the problem again. If you have throttle cables, this whole post is a waste of time.
