Hoop,
The Max on the side wall is the max. Not the amount the tire must be inflated to. The bike/manufacturer stipulates the specs of the inflation requirement for the handling and load rating characteristics. It's perfectly safe and fine to have the tires inflated to less than what the side wall indicates.
Also, you don't need to equipe your bike with the exact OEM tires, you can put on any tire that meets or exceeds the OEM specs for the bike. But, don't let the tire dictate the required pressure. It's the bike/MoCo engineers that do that after extensive testing and R&D for each and every bike.
The only exception is for bikes that are riden off road. Street, stunt, dirt. You can adjust tire pressure for the conditions required.
Do what you like but, you're not helping your ride by over inflating.
I think you missed the point here hoople quoted the metzler recommended tyre presure for his bike with the tyres fitted
the moco quotes the recommended presure for the oem tyre not for every tyre brand that will fit the bike a good tyre manufacturer will have tested their product on many different bikes and quote their reccomended pressure if you are in any way unsure use the 4 psi differential rule i posted erlier that will give a good indication of a fair pressure for your bike with your load the moco does not test the tyre pressures on the bike with every conceivable after market add on fitted its for the stock bike with stock tyres and an average weight rider of i think 160 lbs
