I have the Doran Tire Pressure Monitor on my Road King Classic so I can check my pressures with the press of a button and do so before every ride and also during the ride to monitor the pressure increase from heat so I can set the cold pressure so I get a 4 to 5 pound heat increase at the rear. This gives optimum preformance and tire life. I have found that you will get a normal lose of about 1 pound per week with air and maybe a little less with nitrogen.
Thanks for the replies. I feel better knowing this pressure lose is normal and can be expected. I will just check my tires more frequent. That Doran Monitor sounds like a slick option to have! Tks.
Here's the link to get info on the Doran TPM mentioned:
Motorcycle Tire Pressure Monitoring Systems by Doran
Bobbiegs - couple of questions for you.
1. How much did the motorcycle version cost? Christmas is right around the corner, after all!
2. Did the sensors affect your tire balance noticeably? Did you have to add any weights to the opposite side to get it perfectly balanced?
