hi everyone, just wanted to know if i have done any damage by changing to a leaner pilot jet like the joe minton article in american iron suggested. i tried it and the bike runs good but i have a few coughs here and there. i had like 4 in one day. it still seems a little lean to me but the plugs look good, but i can feel that it just isn't as smooth as it could be if i'm riding around 1/8 throttle but smooths right out at 1/4 throttle. am i running lean enough to do any damage? thanks
Lang
also i running the richer needle from a 1200 in it as well with about 3 to 3 1/2 turns out with the air/fuel mixture screw. i have a 1250 kit with andrews n4 cams, stock heads, se II slipons, arlen ness big sucker II a/c, twin tec 1005 ignition module. thanks again
The coughs are an indication that you are too lean. Also don't use the plugs as a base line to proper mixtures. They will show a white plug tip except for the fuel additives regardless of how much fuel you put in there after the removal of the lead from the fuels.
Running a 45/46 low jet will usually eliminate the popping out the carb. I also don't recommend the early sportster needle. That needle came from a CV carb that didn't run an accelerator pump and the taper is too rich for a CV with an accelerator pump. Sure it will feel good with the seat of the pants but it is too rich.
Running too lean jet wise will show up the bad effects in the long run. Excessive heat and poor running as only an onset of the problems that will show up .
