This engine needed a complete rebuild because the rear piston completely failed, leaving metal all through it and the rear rod bearing was out, I have no idea which came first. I separated the case and cleaned every port in everything, including support plate. I left the oil cooler off because I was afraid I couldn't get it clean enough. The engine fired right up but after running awhile it developed what I figured to be valve train noise. I have a new oil pump and new lifters and have checked everything and when I get the Baisley spring in I am going to do as suggested and put a gauge on it. The crank I put in had less that 20k and rods and wrist pin bushings were as tight and smooth as could be. It runs so nice that if I can get the oil to the top cured I should be fine. Time is limited but when I get it going again I will report on the results. Thanks folks.
