Admiral Nelson
Banned
Its always tricky isn't it. I asked about a torque value on a Vrod forum - had I followed it, I would have sheared the bolt. I managed to obtain a manual for my Vrod and I tended to follow it..
			I found that when torqueing fasteners to use the right size torque wrench. If you try to torque Derby cover bolts to 8ft lbs with a 1/2 drive 2foot long or3/8 drive 1 1/2 foot long torque wrench you will probly stripp or break the bolts if you use a small 1/4 drive tourque wrench you will be able to correctly torque them.
In some cases Yes!. Do you actually believe because the "factory" said so, it is 100% absolutely correct.? I can not tell you the number of times I have found the manufacture to be INcorrect. Even though they developed the product, it does Not mean an improvement or a mistake can not be found.
[ Elmosac wrote : First, why would you not follow the torque specs in the manual? ]
Well that was the question, my thoughts were since the teflon tape (or any pipe dope) lubricates the threads so as to allow easily tightening to a leak proof state, the "torque" or twisting resistance you feel would not be the same as raw metal. Which I would have to assume the torque values are based on raw metal. So you could actually tighten it past the recommended point if you kept going to the documented resistance on the wrench.
It is not leaking and it's tight enough that I don't think it's going to vibrate loose so I figure I'm in much better shape than a stripped thread on my crankcase. I don't have them accessible right now but some Harley manuals (and printed sheets that come with parts) have different torque values for the same parts, it's rare but I have seen it. But of course that last statement is deviating a bit from the point of my question. I have done a bit of house plumbing and the whole reason for pipe dope is to make the tightening of pipe thread easier since in some tight places it can be pretty darn hard to get copper, brass or galvanized to tighten enough not to leak, it tends to bind without pipe wrap or dope and you will keep getting those slow drips without it.
Oh and by the way the reason natural gas codes don't allow teflon tape is because pieces of it can clog the gas fiittings if they get loose in the pipe. I think that is to protect against sloppy work since if you leave it away from the first threads in that won't happen. But most plumbers in my area use teflon on everything but gas since it stops leaks better. I'm not a plumber, (I did work in construction most of my life) but the side plumbing I have done, I have had pipe dope keep having a slow drip leak. I would pull the joint apart clean it up and wrap it with teflon and it would not leak. But again the point is, it changes the torque resistance on the wrench.
Wow…..your reply is quite a bit condescending to me. If you think someone should stick to the manual you should probably just say “hey my friend I’ve been a professional mechanic for years and would recommend you stick with the manual.”
See how much nicer that sound!!!!
