I would have thought in your example - 90 ft lbs was the minimum, and 90% of that would be 81 ftlbs?????B-1B, I don't understand when you say "90% minimum" or shoot for 95%. Lets say my rear axle nut needed to be set to 90-105 ft/lbs. What value would you shoot for. If I understand you correctly, your saying you would tighten it to 95% of 105?
Keep in mind (at least for consumer grade not military) accuracy percentages on torque wrenches are percent of "Full Scale", not "Point of Set" which would give you a horrendous error if you were tightening a nut to 50 ft/lb using a torque wrench that had a 150 ft/lb capacity.
Bill
