wildey
I have been using Craftsman beam torque wrenches for years.
Also the bolt that you are torquing needs to be lubricated to be torqued correctly. Do not torque dry unless it calls for it.
You have this one backwards. ALL bolts are to be torqued DRY unless stated differently in a manual.
Torquing lubed bolts will give an inaccurate torq and it will be higher than you actually set the wrench for which is not a good thing.
