CrazieDave
I’ll post something this weekend ,thanks
I have a 2009 Harley ultra classic bought new in 09. I have had nothing but continual problems with the bearings in the transmission and the primary. They both have been opened up and supposedly repaired 6 times and each time the repair only lasts a short while. Just had it repaired rode it about 200 miles and now the noise is back again even worse than before. The extended warranty is well gone and they have repaired it a few times at no charge but now they tell me due to the age of the bike they will not cover this problem any further. I could understand it but this has been the same issue they cant seem to fix since the bike was new. Im at a loss as to what to do. Maybe I need an attorney
the pinion gear has been grinding on the ring gear of clutch basket too which looks like by the pressure plate
Need photos of the hub and main shaft splines, model year and if everything is stock or modified. Is this a recent development? A short video of the movement would also help.
