Better Hoop than you Jack, then he would have a Jack in the box :34::newsmile040: :lolrolling
GLIDER: There is something wrong...very wrong with you! LOL!!! :newsmile061:
My dipstick did not rub through nor was it behind any clutch cable. It just fell apart, NO JOKE! The cast must have had a weak spot that just vibrated itself apart.
I think the only way Ours would break-off in our newer bikes is IF you tighten down past( way too tight) the snug that is needed on the "0" ring on dip stick.. Then the vibration might snap at the stick part..
You know what i mean,The "0" keeps the long stick from going into harmonics that breaks it off. ,,,(my thinking only)
signed....BUBBIE This was my answer to that problem TOO TIGHT on plug
GLIDER: There is something wrong...very wrong with you! LOL!!! :newsmile061::newsmile100:
Bubbie, I thought you had Hoople in your tool box![]()
A person from another site who works on HD bikes for a living said,
"What really happens is it breaks off from vibration. It gets chewed up by the gears and youd never know it happened, wont hear it wont see it if you pulled the tranny apart. Its a cheap casting that disentigrates pretty quick."
So w/that in mind, even on my 09 of which I saw a wear mark I will be on the safe side and buy a new one for checking it, 32 Oz in and 32 oz out, and cut the old one off and use it for a plug.
Isn't there a saying to Cover This? OH Ya, I remember
"A jack in the Box is worth Two in the Bush" .. or something like that..
signed....BUBBIE![]()
That may be, I rode a 92 FLHS, and a 97 FLHT for 50k plus miles both 5 speeds and never had any problems and I had the sticks out alot
