flhtcutg_tri_glide
Hi all, I'll try to answer the questions and comments in here the best I can.
On stability, the Tri-Glide is very hard next to impossible to tip over.
At low to mid speeds it will push the front wheel if turned hard. At high speeds if a rear wheel comes off the ground all power goes to that wheel. With no power on the ground, it slows and the wheel comes back down.
Also there is a steering damper to reduce headshake.
rbrian, the reverse motor is not a starter motor. It is designed to be a reverse motor and at $1000.00 retail is more durable. There is a new trunk seal and lock for water leaking into the trunk. Did you try to adjust the door strikers to make it tighter? Maybe try that. If that still does not work go to your dealer and submit a warranty to get the new door seal. Not sure if the new lock is part of the warranty also.
mrkihn, the tri-glide is NOT a Lehman's trike. It is totally designed by Harley-Davidson. The front portion is assembled in York and shipped to Lehman where HD has built a facility to finish assembly of the tri-glide with all HD tooling and equipment. Lehman is finacially resposible for finishing the trike's rear end and fit and finish.
If anyone has any questions on the tri-glide I'll try to answer them the best I can.
