Hoople
Account Removed
Up here we're not that smart.
Down here we just pump more air in the tires!
(1/4" is not a lot to play with. It may be an issue.)
Bit the bullet and ordered the PittBull with the TriGlide adapter. They have two adapters one for factory trikes and one for after market builds. You slide the jack under and the install the adapters on each side. Can be made a little easier by riding the rear tires up on boards but not necessary.
The std. Pittbull is what is recommended along with the correct trike adapter. The adapters are not yet up on the site but both Heather or Mark can help. Either adapter is $59 extra. Planning to put in the lift kit that Trike Lady recommended which will bring the trike higher and then eliminate the rear board lift. The lift is on sale till the end of the month so give them a call if interested. Nice people to work with.Can you give any details on what model Pitbull you got and where the adapters are on their web site? Thanks.
Been looking @ pit bull saw them @ Americade last summer,but have been using car ramps. Drive up on rear tires use floor jack to lift front,from under plate below oil pan then put one under front tire. I can fit under bike to inspect and work on,makes changing fluids easy. But then again each to there own!!
