Two wires, then your single phase. Now I would place a DC voltmeter across the battery posts and check the DC voltage at 2500 RPM. Get a reading to two places (12.XX). Also get a reading at 1000 RPM. (which should be about your idle speed?)
You should be in the 14's at 2500 RPM. See if you get a healthy reading at 2500 RPM. Something like 14.30 to 14.70 would be nice.
Increasing the RPM above 2500 RPM really should not lift the voltage a whole bunch more. It really should be peaked by 2500 RPM.
i'm getting 12.57 volts at idle, but its like surging, 12.5x to 11.2x back up to 12.5x and back down , like 3 to 5 seconds between them, when running at 2500 rpm
