have you guys "SEEN" the fuel pump in the tank. The pump is rarely "submerged" because it stands straight up. there is also a "sock" on the end of the pump so don't think you would be sucking up any "debris"
I own a carbed bike with a fuel pump and I run it dry every time I hit reserve. been doing this for 10 years and 74,000 miles. The fuel pump still works, so I don't think running out of gas once is going to ruin or cause premature failure in the fuel pump. Now I know what they say, and I understand the way of thinking but........:dknow
Fine rust particles can slip through the "medium fine screen sock" and when mixed with varnish deposits ends up as a brown "slurry" in your carb...just open the drain of a 3 or 4 year old bike, and look at what comes out, then pull the float bowl, and wipe with white paper towel...yecch, even if you are diligent just fillingup and riding regularly (we can do that in SoCal. I for one try to put an inline filter (usually easily replaced paper pleated one that is clear) so I can see if anything is getting past.
You know Murphys' law...I use one of those reusable "Gold Filters" fine metal screens in my coffee maker, now there is when a little bit of "fine" grinds slips thru, it gives the fluid that passes more "character" is a good thing, but still have to replace in about 5-7 years.
