dolt
Well-Known Member
TT410 attached. This is throttle stop screw issue; pretty common with EFI '07s. The screw will come loose from the factory setting and needs to be reset and locked with thread locker. Difficult to fix unless one is running the TTS Mastertune; maybe the DJ Power Vision wil allow the setting the be changed as well; not sure. Probably a dealer fix for the OP as the voltage setting is in the ECM.
