Re: Bike performance is sporadic
Leave the high speed at 190 and drop to a 46 on the low jet. In these bikes, the top end is usually jetted OK but the bottom end and needle settings are lean.There has been many that had similar problems with the DJ kits and switched back to the stock parts with modifications to the jetting and raised the needle with shims and worked better.
Vacuum leaks as in intake manifold seals to the heads and carb.
Finding An Intake Leak - Harley Davidson Community
