free website stats program Turn Signal issues | Page 2 | Harley Davidson Forums
Turn Signal issues
Take a peek at the wires on the back of the ignition switch to see if there's any green or corrosion at the terminals. Maybe a bad ignition switch?
If you remove the starter relay and it works you more than likely have a short in the power (orange/white) wire or a bad switch.DO NOT THROW MONEY AT ELECTRICAL PROBLEMS.Search until you find the problem and then correct it.No other way works.You will spend more money buying parts than paying someone else to do it for you.Remove the switch housings and look for a pinched orange wire.If nothing there remove the fairing and look for an abraded/broken wire.
