R_W_B
Senior Member
Man, glad I read this. I just purchased the kit from the dealer the other day, along with a few other things. This appears to big a bit of a pain to do since the wires are in the handlebars. I have not looked at the instructions just some manual reading. From the looks of it I am going to need to remove the tank.
Other than what has been written here, any other tips, tricks or info on what to expect when doing this. How much time will I need. The bike is still on the lift from winter and suspect I probably got close to another 4 weekends at least before the weather breaks for a ride, so want to start this soon.
It's not that bad, I ruined my AMPs with ignorance. If you do them correctly you won't have my problems above. It is easier if you remove the tank. You could just remove the front tank bolt only and prop it up enough to get to the plastic plate under the frame neck.
Even to do that you prolly need to remove your fuel disconnect, your fuel gauge wire connector separated and the crossover tube separated. Just wrap a towel over the fuel disconnect before popping it off since it will spray fuel just for a second. (Always disconnect the neg bat cable first)
For the rest of the tank removal do a search on Tank Removal, it's been covered. I will try to find a link to an excellent video of How To for the AMPs but right now I'm short of time. I don't like working the wiring around the crossover so I drain and remove mine.
Here I found it pretty quick. Notice the twist of his hand. Also make sure you insert the tool in the correct hole (I didn't and I reamed out my AMP sockets)
YouTube - **AMP connector**disassembly**part 2**
