cdn-bigfoot
Junior Member
they put the vent holes in the front so you so you won't get staining on the tank from the condensation and moisture build up which is fine.But you are getting rust because they cheaped out on the zinc.coating.Clean it.Tremclad it,put it back together and forget about it.
I agree.
The vent holes need to remain at the front and rear of the tank dash panel. Otherwise any moisture that gets in through the gauges (and it will) has no way to dry up. I'm going to clean it up with a Dremmel, acid bath and then powdercoat it.
