Well, my luck continues to go south. Cleaning the IAC lasted about a week and the idle problem came back. Ordered and installed a new IAC. Initialized and cranked her up. Idled fine. Took it for a ride. No different. Idle dropped out at the 1st stop. Engine light came on and went back off. Tried to pull codes. No codes. Removed the Fuel Pak completly. No different. I checked for intake leaks and found none. ?????? Starts and sounds fine. But, it sounds like its starving a bit for fuel after riding for a few minutes. Any thoughts as I dread the thought of taking it to the dealer.
More to add. Went back out a started the bike. It idled fine and sounded good. Throttled it up a few times, sounded fine. After a few minute of running I could feel the bike heating up. Throttled it up a few more times and it died. Cranked right back up. Then the engine light came on and stayed on as long as I held the RPMs up slightly. Still no codes. At one time the bike idled high after I backed off on the throttle. Could the intake air temperature sensor be bad? Seems like I should get a code if the eng light comes on??????
