J Jack Klarich Guest May 14, 2011 #21 Have you looked at the swing arm bushings, it is a long shot I had a 1980 FLH do the same thing the swing arm bushings were bad
G gec1995 Member May 14, 2011 #22 No I havent checked the swing arm bushings.I probaly should and replace the front bearings.thanks
J Jack Klarich Guest May 14, 2011 #23 gec1995 said: No I havent checked the swing arm bushings.I probaly should and replace the front bearings.thanks Click to expand... If the bearings were just packed you can check them for play as already mentioned, also with the wheel jacked up as you turn the wheel grab the fork legs if the bearings are bad you will feel a vibration in the fork legs:s
