have a 2008 electra glide standard, and when i rode it today i noticed it has a bad vibration. it always vibrated while idling but would smooth out when giving it the gas. today it felt sluggish when taking off and felt vibration on the handlebars and on the floorboards and the windshield pouch was even vibrating real bad even at highway speed. not exactly sure where to look but i know something isnt right. it also felt like i needed to change gears alot sooner then before. any suggestions where to began to look for the problem would be appreciated
MAN,
I Hate these post to answer.:bigsmiley15:
It could be many things Like the engine touching the frame, IF you have an adapter on a Jagg oil filter that has Moved and is touching the frame. It Did happen to me. Really shakes ALL
Being an 08, saying you have always had excessive vibration, It MIGHT be a Crank out of tolerance.
Not saying to start there as a Bad Crank, BUT it would not surprise me.
Have you changed the Plugs or Taken a compression check lately? How many miles on this bike.
Those are the first thing to check though to see IF it is something simpler than the
CRANK.... Let's Hope So.
I'm not there to understand or Feel the vibration. HD would probably Not charge to just give you an Opinion...
Do you have an extended warranty?
Blessing if you do...
Others May not be as BOLD as I was going for the DREADED Crank,,, BUT skirt around this problem.
I'm Hoping they come up with easier to swallow diagnoses/remedy for this problem.
