Hoople
Account Removed
I was under the impression that grounding the blue wire actually lets it run up to 35 advanced.
Thanks
Yes, the VOES switch is suppose to be normally open which would mean removing the wire FROM ground would retard the timing. So you are correct with the logic state of the VOES switch. So ask Gary how much spark advance will be removed from the 35 degrees when you remove the Blue wire from ground. Also confirm if spark advance are steps and not a curve. The manual was not clear regarding any of these points.
I am guessing the blue wire is responsible for maybe 5 to 7 degrees. That would put you around a more realistic number of 28-30 degrees of total advance.
Just a guess.
