Hi there, all, I have a question for the gurus.
I went to change the oil, filter, spark plugs, and tranny/primary fluid in my 2008 Sportster 883. This bike is a repo, so it's history is unknown until it came into my possession. A little over 6k miles on it. And it's from Texas (I live in Michigan).
Everything went well (that oil filter was quite difficult to remove, but I got it!), until I took out the drain bolt for the tranny/primary. What came out can only be described as a beautiful, silver-colored sludge. Completely silver colored. The tip of the drain bolt had a very small amount of debris on it, nothing too bad.
I made sure this thing drained very well (I took it on a 15 minute ride before I drained it to warm it up and mix things up), and then I cleaned all of the foamy-white
(EDIT) off of everything I could see (the clutch adjustment bolt, derby cover, drain plug). I then proceeded to put some Spectro Heavy Duty Primary Chaincase Oil in, which is a nice transparent color.
The bike rides about the same, but shifts sooo much smoother.
My question is: How would water get into the transmission/primary? It would seem a fair amount was in there, as ALL of the oil that drained out was a consisten silver color.
Secondly, could I experience some long term damage from this aqueous exposure? Short term? Is this slightly normal? The bike did get a fair amount of condensation on it over the winter storage, enough so that water was dripping off of it.
Thank you guys very much!
Doug
