Hey! I resemble that remark!!![]()
:bigsmiley20: Which do you resemble?
Other than what Glider said you can drain the oil from the bottom of the crank case and tell if your sumping, the little plug in the bottom will come out, just put a piece of 2x4 under the kickstand and drain the oil after you've rode it about 15 minutes or so, don't let it idle much before you shut the engine down, now get a good clean pan or something to catch the oil in, take a riderite ratio cup and measure the amount of oil you have, should be between 4 to 6oz's, can be just a little more say 7, but if it's 10 or 12oz's your sumping, the oil pump o rings or the oil pump itself could be leaking back into the case, hope this helps.
When reinstalling the plug be careful, it is a pipe thread and you will not want to overtighten or it will bust the case, just snug it up, put a couple wraps of teflone tape or pipe sealent on the plug before install.
Hey guys, thanks for the response, but my motor has that port and should not need to be plugged. I have tried installing the o-ring from the pump to the sump(case) a couple of different ways several times now. I have placed the o-ring on the pump stub and I have tried placing the o-ring in the case first and then push the pump stub into it. Neither has gotten results. O-ring looks to be in good shape everytime I pull it out. No pinching, kinking, or tearing is present. I stuck my bore scope, a great tool to have for this project, down into the sump housing to look for any debris that might have been clogging the hole. There wasn't any to be found. It seems as though I have gotten to deep into this project and I am now chasing my tail. If you have any other ideas I would certainly welcome them.
THaaaaaNKS, 06kicks
P.S. I forgot to mention that my oil pressure is right at 32p.s.i.
