Sheepdogmarine
Another thing you may consider is getting a smaller dirtbike first. Don't get a crazy two stroke, but a nice smooth four stroke. They are very easy to learn on, very manueverable and you won't cry if you drop it or scratch it. I am sure you could pick up something for a couple grand tops and then sell it for that when you are done with it.
There are some very valuable lessons learned riding on dirt or grass that may pay off big time the first time you ride a street bike across wet grass or loose gravel. It also does not hurt as much if you fall over in grass instead of on asphalt. Well, usually.:s
I also feel that if you get comfortable on that, then switching to the bike you want is not such a big deal. I have a Fatboy. It is low, well balanced and very easy to ride. Don't let the weight of the bigger bikes scare you, most have a lower center of gravity so you don't notice the weight.
There are many good points brought up in this thread. Just don't let someone talk you into something you don't want.
Good Luck!
Good Luck!
