angrysanta
I have an 08 XL1200N with SE Stage 1 AC, V&H Side Shots and I chose the Fuel Pak for several reasons. To go with the pipes, assuming that V&H made both Fuel Pak and pipes that they should work well togeather. Also the price for the Fuel Pak was 234 dollars. I also new I did not want to have to dyno tune the bike and I had heard the Fuel Pak was plug and play. The install was somewhat tricky as there was not alot of room to put the Fuel Pak but I got it in. The initial map I programmed had some problems like backfiring and popping but I was able to call Fuel Pak on the phone and explain the symptoms. The tech had me change one of the values in one of the modes and that solved all the problems. The bike runs very well and I am impressed with the new performance of my bike. I am happy with my choice and time will tell if there are any reilability issues with the fuel Pak but It seems to be made well, The module is completely encased in epoxy and the harness and connectors are of at least the same or better quality than HD.
