R_W_B
Senior Member
R_W_B
If you are running tubes in the tire the moisture problem should not come into play as you pour the beads in thru the valve stem when using tubes.
Thanks, that is a good point that I had not thought of. However I'm still interested in input on the former question because someday I hope to buy cast wheels and get away from the tube (and so many spokes).
