Brennerad
Do you think the use of the deflectors may block the ventilation to engine and cause the engine/oil temperature to rise? I live in hot weather most of the year and i did notice an increase in the engine temperature after instaling the deflector and removing the screaming eagle II Slip-On Mufflers and changing for the stock mufflers, whith less air flow off the exhaust. So, i don't know if the change in temperature is due to the mufflers or due to the deflectors blocking air flow to the engine. I am reading oil temperatures around 260º F.
