harley@16
Junior Member
If you have a Gen 4, the easiest way to diagnose a problem, you have to unplug the guage and not disconnect the ground. The bike will not run at all if you disconnect the ground and leave the injector wires attatched. Unplugging the guage will take the function away from the o2 senser and and fuel modification, you will be operating only from the ECU. The guage will be off. This is easier than removing the injector wires for a test.
